An abnormal condition has been detected which, although it is not interfering with the normal operation of the system, may signal that the system or the network in general may not be functioning as expected. The condition may have been caused by an unusual or unexpected circumstance related to some external stimulus.
The exact remedy is dependant on the particular situation; but the condition may be resolved by retrying the operation when the resource becomes available.
Warning
A request to get the version code of the IO card in slot %slotNum% with assigned ip address of %slotIp% failed - returning a completion code of %return_code% .
| Name | Type |
| return_code | sInt |
| slotNum | uInt32 |
| slotIp | srcIPaddress |
